Product Forums
Home Automation Forum
Smart Home Developer Forum
Community Activity
Tell it twice to stop?
When I play a radio stream on my hub {or mini for that matter) and I want it to stop I have to say it twice. It does listen to me on the first request (music stops for a second) but then it just keeps on playing untill i tell it again to stop. This b...
realjax by Community Member
  • 5 Views
Do unmanaged TP Link switches work well with Nest Wifi Pro?
I am planning on adding a 10G switch to my nest wifi pro and based on the discussions online I have realized that I can't just add any unmanaged switch. I was thinking of getting the TP Link TL-SX1008. What should I be looking for in the specs to mak...
nibi by Community Member
  • 22 Views
How do I completely lock a 1st gen nest thermostat?
I have a 1st gen Nest Thermostat. The lock function requires me to enter a temperature range, and anybody physically accessing the thermostat can turn the AC or heat on within that range without using the PIN. How do I completely restrict the thermos...
Sir_Argo by Community Member
  • 24 Views
Intercom between Nest speakers no longer works
The best service that Google offered for those who had installed a speaker in each room of the house, even on different floors, was the possibility of making voice calls from speaker to speaker. Now it seems this service has been suppressed and it is...
Simone73 by Community Member
  • 25 Views
Nest Learning Thermostat (3rd Gen) Wiring
I have a WaterFurnace NDV049 Envision geothermal heat pump. Below is the wiring for my previous t-stat. How should I wire the NLT (3rd gen)? I've tried a couple different things but it doesn't seem to be getting power. When I place the display on the...
MarkZ79 by Community Member
  • 27 Views
My Nest Hub Max seems borderline useless
With the latest update. My Hub Max seems another step closer to being useless. Can’t access my cookbook anymore. It tells you to go to Google.com/saves and the built-in browser takes you to some useless help page when you tell it to go there. I’m rea...
eisenb11 by Community Member
  • 24 Views
Nest baseplate at it again
I had this same issue 2 years ago. After a solid 2 years of operating fine, the nest baseplate craps out and fails to provide enough voltage to the AC to switch over the compressor from the heat pump to the cooling side. So as my system runs all day ...
Niceberg by Community Member
  • 46 Views
cec controll suddenly stopped working
I have a chromecast 4k connected to a "older" JVC tv, set up to 1080p.It has worked without any problems, up until recently. For some reason that i don't understand the cec function is no longer working.The chromecast is connected directly in to hdmi...
