My google nest wifi router keeps restarting on its own and its getting real annoying. The below mentioned is what I have done so far that didn't help. If you're using a modem/router combo, set that to bridge mode to avoid double NAT issues.Make sure ...
Per the title - I only want the camera to turn on when the doorbell is rung. It's a bit uncomfortable for my neighbours to constantly feel surveilled otherwise. Is this possible?
Hi,I fear I'm experiencing a problem I've seen mentioned multiple times on this forum.My Thermostat, out of the blue, lost WiFi connectivity. None of my other devices did.I tried:* Resetting my router (although none of the other devices had any issue...
This morning, I woke up to no wifi at my home and when I checked on the router unit it is showing a solid white light. It seems weird that it was showing that but not working. I power cycled the unit, it just goes straight to the solid white light, d...
The german translation of the abbreviated weekdays at alarm clock settings for thursday is wrong. Thursday is Donnerstag in german, abbreviated it should be "Do" and not "Di", which means Dienstag (Tuesday). Google nest hub 2, Fuchsia 16.20231130.3.5...
I've always wanted to find an alternative to using YouTube music. It would make me really happy if there's a way to do this. Please let me know if this is possible. Thank you!
Just read a very sad story , but Nest thermostat is no more, gone , dead. Cover while in Warranty further back kit Nil which may explain some of mail about Nest, Sad ! not really after trying for 3 days to connect to WiFi after 2 years without proble...
Changing Color via automation on the google home app has stopped working. I have tried to de-link - relink the apps but still doesn't fix the problem. Only works if the automation is manually triggered. Other commands like brightness/on-off work but ...
Hello!I am bought a European version of Nest Learning and plan to connect this to underfloor heating using the LG Therma V heart pump (220V) . This will be connected with the Heatlink box. It is a new apartment with no existing thermostats yet. The h...
