Product Forums
Home Automation Forum
Smart Home Developer Forum
Community Activity
Preheating too early
I have my Nest Thermostat set to raise the temp from 72 to 74 at 1:00 PM. I have Early On set to a maximum of 1 hour. It has worked fine for over a year. Today, the thermostat turned on the furnace (forced air / gas) at 11:00 AM, which is 2 hours ear...
zunkman by Community Member
  • 3 Views
Resolved! Just moved in, nest does not have cool mode
Hello, I just moved into my new home, Im setting up the Nest with my Home app but no Cool mode detected. Any help would be greatly appreciated. I checked and it the wiring, it appears correct to my knowledge...
Camera is offline
I need help to get my camera on . I tried resetting, disconnecting the power supply, deleting the nest app and reinstalling the Nest App, After all this it shows Offline
MCE3458 by Community Member
  • 28 Views
Two stage cooling No OB wire
HiI understand that heat pump units should have a OB wire. In this case, I don't. I checked the wiring on the furnace and the blue wire goes to Y2. The rest of the wires match on the thermostat and the PCB. Is this possible? A two stage heat pump uni...
Wallsroy by Community Member
  • 25 Views
Google Home not linking to Lifx Services
Hi, my Lifx lights were appearing in Google Home, however Google assistant was not able to access them. Saying "something went wrong, try again..." Over and over.I thought if I just unlink Lifx from GH, and re-link, the problem would be solved, but i...
MandaC by Community Member
  • 61 Views
Nest doorbell camera damaged lens.
We love or door bell camera. It's awesome but unfortunately it sprung off hitting the concrete wall and ground, this has scratched the lens ever slightly creating a blur and no longer crystal clear.Very annoyed by this happening, is there someway I c...
Tizzy69 by Community Member
  • 61 Views
Nest looks ok, but not heating
Our nest is showing a normal screen like it’s working but the central heating is not coming on. Earlier today our plumber nicked a whole in a pipe so we had to shut the boiler and water off, but that was fixed, and shouldn’t have impacted the nest, t...
Penny76 by Community Member
  • 55 Views
