Product Forums
Home Automation Forum
Smart Home Developer Forum
Community Activity
REGULAR MINI DISCONNECT
THIS ONE UNIT DISCONNECTS REGULARLY AND ASK FOR A NEW 'SETUP' EACH TIME. IS THIS 'NEW' NEST FAULTY?ONCE SETUP, IT WILL WORK FOR A TIME, BUT THE NEXT DAY I WOULD HAVE TO START OVER AGAIN. THIS IS ANNOYING AND NOT WHAT I PAID FOR. I HAVE 2 OTHER UNITS ...
GC10 by Community Member
  • 21 Views
Sleep sensing keeps failing to calibrate
I decided to recalibrate my Nest Hub one day, and it says "calibration failed". I move the Nest Hub around, close curtains, turn off lights, and retry calibration. It fails again, so I move the Nest Hub a bit more. It's level with the mattress, about...
karmayxzu by Community Member
  • 21 Views
Nest doorbell battery notifications
Is there a way to select different Nest Doorbell notifications pushed to different devices? I'd like to recieve "Person seen" and doorbell notifications to my Android phone, via the home app. But my wife only want the doorbell notification. Is it pos...
Issue with Android Tablet
I installed Sophos Intercept X for Mobile on a new Tablet. Intercept X is showing: “Android compatibility verification FAILED” indicates the Android OS on the tablet is not validated according to Google's validation tools. It might not be an unoffici...
DerNev by Community Member
  • 27 Views
Connecting Chromecast to new WiFi
I removed my device from the Google App because it wasn’t connecting when I trying to set it up. I was trying to connect it to a new wifi but I realised that might have been the wrong move. Is there anyway I can re-add the device I deleted or do I ne...
Larrybr by Community Member
  • 34 Views
Chromecast remote setup
Unable to get chromecast to power on/off my Vizio tv. When I go to setting to set up, and select add TV, nothing is listed and it jumps back to the previous menu. Help!?
Charging Port Cover
I’m confused by the lack of silicone cover to protect the charging port of an outdoor device. I’ve had to replace several cameras due to the corrosion of the points that connect to the charger. It feels like planned obsolescence, which in my case by ...
MAH17 by Community Member
  • 29 Views
Network failure
Nest cannot connect on network w-5 code screwdriver and pliers at crisscross showing on my screen..all other electronics work perfect as always for yrs. Thermostat disconnected from WiFi …...no matter what will not go back on line..went through all s...
do2 by Community Member
  • 37 Views
