Product Forums
Home Automation Forum
Smart Home Developer Forum
Community Activity
Suggestion for a Government Resource Database
Subject: Suggestion for a Government Resource Database GloballyDear Google,I know this forum might be irrevalant to my request but unfortunately there is a lack of Information about where I should post project topics for Google Even after searching f...
pooyair by Community Member
  • 6 Views
3rd gen Thermostat not working
I have same problem like in this link with other user https://www.googlenestcommunity.com/t5/Nest-Thermostats/Problem-installing-wiring-my-Nest-Learning-thermostat/m-p/426058#:~:text=In%20order%20to%20use%20the,HVAC%20system%20a%20Heat%20Pump%3F Same...
Surpreet by Community Member
  • 13 Views
Nest running heat pump - cooling but not heating
Nest Gen 1 running a heat pump.System works properly with old thermostat.Wiring transferred from old thermostat in same wire positions.Cooling turns on air handler and compressor and cools the home.Heating turn on the air handler but NOT the compress...
jlehm by Community Member
  • 10 Views
Google nest and Apple Music
I’ve linked my Apple Music account to my Google nest and for some reason it won’t play my actual playlists that are on my Apple Music. I’ve tried unlinking the account and relinking but that hasn’t helped. Both devices are on the same network and bot...
device offline only on one phone
This afternoon I opened Home app and all of my devices are offline except google products (Chromecast TV, nest Speakers, nest hub, router). All smart plugs, air conditioners, bulbs, etc are listed "offline.My wife's phone (she is a member of the hous...
spoken by Community Member
  • 33 Views
Thermostats
I want to verify my wiring is compatible with Nest. please send a link that I can upload a photo.
