Product Forums
Home Automation Forum
Smart Home Developer Forum
Community Activity
Can't connect to Nest Thermostat after new phone
Hello,First time I tried to get into Nest app on new phone and it doesn't connect to the thermostat.I can see the schedule etc on the thermostat, but phone doesn't see it..If I try to add a new Thermostat it wants an 'Enter Key', but there is no key ...
Redeye66 by Community Member
  • 1 Views
Chromecast Fernbedienung funktioniert nur teilweise!
Bei der Fernbedienung funktionieren die beiden seitlichen Tasten Lautstärke, Stummschalten und TV-Eingang nicht. Alle anderen Tasten funktionieren problemlos. Mit der Originalfernbedienung des Fernsehers (Typ: Samsung UE43KU6640U) und über das Smartp...
Noeggi by Community Member
  • 9 Views
Acont linking problem
Hi team ,In the account linking section, i have put my new OAuth link for authentication . The same skill is present in live now i want to test that account linked to the development environment. How to do that? I am new to this . I need your help. I...
Nest App Still DESTROYS Google Home
First off - The delightful surprise once you setup one of these new cams that you cannot integrate it into the Actual Nest App, is a straight up con-job scam. Secondly - The Google Home App is SUCH COMPLETE GARBAGE, literally across the F’king board ...
