My Nest thermostat will not reconnect to my WiFi network. I have tried everything suggested to fix, and have spent many many hours trying to connect to my network.i have 2 Nest Learning #3 and this one will NOT reconnect. I have been told that my act...
Can I use a nest router as a point. I.e. not have an Ethernet cable attached? Reason is I already have a router I just need an additional point. Thanks
Yesterday my Chromecast suddenly hung, powering it off and on did not help, so I ended up having to do a factory data reset on it. After the reset I switched it into apps-only mode and installed the same 7 apps as before.Before the reset, all apps co...
For no reason at all, my nest has started to set the temperature to 32C. We leave on all year round but in summer months it rarely comes on, as you'd expect. So a bit of a surprise when the heating comes on an attempts to heat the house to tropical l...
I can only stream 6 of my 8 cameras on the Nest Hub Max. The 2 that doesn't stream show up fine on my phone in Google "Home" app. These are Lorex brand cameras and their app shows the cameras fine. The Nest Hub Max would try to start streaming but th...
My google nest wifi router keeps restarting on its own and its getting real annoying. The below mentioned is what I have done so far that didn't help. If you're using a modem/router combo, set that to bridge mode to avoid double NAT issues.Make sure ...
Per the title - I only want the camera to turn on when the doorbell is rung. It's a bit uncomfortable for my neighbours to constantly feel surveilled otherwise. Is this possible?
Hi,I fear I'm experiencing a problem I've seen mentioned multiple times on this forum.My Thermostat, out of the blue, lost WiFi connectivity. None of my other devices did.I tried:* Resetting my router (although none of the other devices had any issue...
