Product Forums
Home Automation Forum
Smart Home Developer Forum
Community Activity
Unable to reconnect to my WiFi (nest.com/2)
My Nest thermostat will not reconnect to my WiFi network. I have tried everything suggested to fix, and have spent many many hours trying to connect to my network.i have 2 Nest Learning #3 and this one will NOT reconnect. I have been told that my act...
mike911 by Community Member
  • 7 Views
Nest router as a point
Can I use a nest router as a point. I.e. not have an Ethernet cable attached? Reason is I already have a router I just need an additional point. Thanks
Huge app icon size after resetting chromecast to factory data
Yesterday my Chromecast suddenly hung, powering it off and on did not help, so I ended up having to do a factory data reset on it. After the reset I switched it into apps-only mode and installed the same 7 apps as before.Before the reset, all apps co...
Vvk1 by Community Member
  • 15 Views
NEST randomly setting high temperature 32C
For no reason at all, my nest has started to set the temperature to 32C. We leave on all year round but in summer months it rarely comes on, as you'd expect. So a bit of a surprise when the heating comes on an attempts to heat the house to tropical l...
wags2e by Community Member
  • 14 Views
Need help Adding product
Product installed prior to scanning. I cannot remove to scan however I have the box product came in. Can I use serial number on box?
Nest Hub Max won't stream all cameras
I can only stream 6 of my 8 cameras on the Nest Hub Max. The 2 that doesn't stream show up fine on my phone in Google "Home" app. These are Lorex brand cameras and their app shows the cameras fine. The Nest Hub Max would try to start streaming but th...
Triton74 by Community Member
  • 36 Views
Wifi router keeps restarting by itself
My google nest wifi router keeps restarting on its own and its getting real annoying. The below mentioned is what I have done so far that didn't help. If you're using a modem/router combo, set that to bridge mode to avoid double NAT issues.Make sure ...
WJLIM by Community Member
  • 24 Views
