Trying to connect speaker after connecting to internet. I get a message saying “Master Bedroom speaker may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your iPhone's privacy...
The wiring diagram for Icomfort thermostat showing the 4 wires R, I+, I- and C - this is for Lennox 2 stage HVAC system (furnace and AC). How can I wire the Nest Thermostat
Bonjour, Je me permets de vous contacter car je ne comprends pas pourquoi je n'arrive plus à caster. Je m'explique. Je possède un ampli et un vidéo projecteur de la marque Optoma. L'ampli qui est relié est un Yamaha - HTR2071.Tout fonctionnait très b...
Got a new Router. WPA3 capable. Switched to WPA3. All my tech happy with that apart from the Nest thermostat which then rejected the WIFI. Went back to WPA2, Nest happy again but all my other tech were not. I now have the choice of WIFI for my laptop...
Just bought 3 Nest Protect Gen 2 smoke alarms today (13May24) and installed them. 2 work as advertised, 3rd indicated a low battery caution.Nothing new here other than another often reported false battery low indication. Send me the paperwork to have...
I have Icomfort thermostat with 2 stage furnace and AC system. The Icomfort thermostat has 4 wires R, I+, I- and C. How can I rewire the Lennox panel to connect Nest thermostat.
I'm having multiple issues with my cameras not loading video in the home app. We have the Nest wifi and all cameras have good signal. ( our house is only 750 sq ft) It's when I go to view the video feed, either live or recorded that it takes foreeevv...
Are there plans in the pipe for upgrading the Chromecast w/GTV HD/4K to bring their WiFi adapters a bit more current (and maybe add in some more storage while we're at it)?
I had 24/7 video history for the past 4 years and all the sudden my subscription got canceled without notice. When I called to see why my cameras weren't working I was told my subscription ran out. After renewing it the only video history I could get...
