Product Forums
Home Automation Forum
Smart Home Developer Forum
Community Activity
Google doesn't Play what I ask for!
All of my Google devices (Google Nest Hub Max Display & 5 Google Minis) often won't play the song I request!Example, "Hey google, play the song I Love you by Sarah McLachlan".Response: "Okay, playing on YouTube music, Love to Love You Baby".Second at...
Prima by Community Member
  • 37 Views
can't connect to app
I have tried connecting via the app and keep making it to the last part where it say finishing connection. I get the TD009 error. I have tried doing the factory reset on the device and restarting my phone. I had previously successfully connected the ...
Ken14 by Community Member
  • 20 Views
Customer service is terrible
My nest camera weatherproof 10m cable failed after 11 months, and Google will not honor the warranty on their own accessory. After chatting with their support, which ended with them telling me to contact Amazon for the return knowing it was purchased...
MoDat by Community Member
  • 47 Views
Disable eco mode or smash nest thermostats with a hammer?
I’m sick and tired of coming home from a hot day of work to an 85 degree house thanks to “eco mode”. I’ve combed through 50 posts about this and google results and every one of them says to simply go into the google nest app and turn it off. The prob...
ijasond by Community Member
  • 78 Views
My door bell has quit ringing inside the house.
108 by Community Member
  • 23 Views
frustrated with nest
the house will not get below 80 degrees'.the green "leaf" icon shows even though it is shut off.We are boiling. We have a new (8 monthold) large air handler and top notch a/c central air installed. It stays 80 degrees all day and the "history" shows ...
Watchdude by Community Member
  • 35 Views
Thermostat sensor
We bought our home from a couple that relocated to Singapore and unable to get in touch. I was able to reset the learning nest and connect to our app but the sensor continually says connect to another account. Took battery out for 10 minutes and trie...
